Shock Absorbers!!
  • Shock Absorbers!!
    hi my truck is in need of some new shocks, but haveing fun getting hold of some as the ones fitted at the mo are after market type,no electric adjustables..
    can anyone help with replacement ideas?
    currently fitted are (ohlins-ct5-c) 32 position adjustables(by hand)!
    cheers dan
    cheers dan
    take a look here but it all depends on how much you want to spend
    http://www.explorerprocomp.co.uk/aca...ms_Toyota.html
    http://www.supertrux.com/acatalog/4_..._Lux_Surf.html
    http://www.toyotahilux.com/
      cheers chap,i think it has a lift kit fitted as it is very high off the arches,front and rear, so would look at the es3000s as long as i get the right lenght ones!!
      cheers dan
        cheers dan
        i am fitting a 3" lift to mine soon and i am in the proccess of ordering all the bits.I am getting +3" es3000's for the rear of mine and +2" for the front.Have a chat with Tonyn at www.4x4toys.co.uk if you have trouble getting the shock length you need as he may be able to help you out
          ok cheers richard will do,good luck with the lift kit,cheers dan
            You could try getting current shocks rebuilt - most Ohlins shocks are fully rebuildable.
            Peter
            I am not a number. I am a FREE MAN!
              Why the hell would anyone need 32 different settings from their dampers?
