Hi all?.
Just bought a 1991 2.4 no probs so far, untill. On way home friday the power steering went heavy, assuming after driving home found fault, Adjuster bolt has come loose as i gained accsess to tighten it it decided to fall off now this is where it all starts.
Removing the radiator the first thing is the finns are all corroded away at the bottom so need info for any good core repair or new but i'm sure this will be expensive.
Having to cut the retaining bolt in to pieces due to the pully on the steering pump is very tight and cannot get past the pully wheel, where can i get a new bolt from is this a toyota part?.
Again on this nature i noticed the cylinder head has a leak of oil from the gasket area on this note i'm sure the head gasket has gone but has not overheated to date so will have to sort out if possible any suggestions on this or advice please, Or good parts supliers for the over all repairs?.
