Can somebody shed some light on this - so i know which bits to start pulling apart first!
I have oil alround the rear off-side wheel arch, which seems to be leaking from within the wheel itself?
the break fluid level is fine, and it's not the shock. So is it the diff oil seal? Is that where the oil normally leaks from??
I've read similar threads about how to replace it, but a diagram would be helpful if someone has one, and any other guidance as I haven't played around with the diff before, so don't really know where to start trouble shooting
TIA guys!
TIA guys!
