The missus managed to get too engrossed listening to the penalty shoot-out when she was at the petrol station tonight and managed to put £20 of unleaded petrol in our 3.0L diesel Surf (2nd Gen).
She called me to tell me what had happened just after the penalty shoot out finished... as you can imagine, her impeccable timing really helped cheer me up after the England result!!
The tank was almost empty when she put the petrol in so there's probably about 5 litres of diesel mixed with 20 litres of unleaded in the tank.
Fortunately she re-engaged brain and noticed her mistake before trying to drive off so when I got there we towed the Surf home. (Fortunately I had the works Nissan Navara so towing the Surf wasn't really a problem). It has NOT been run - or even turned over - since her little faux pas.
Question is: how do I get the unwanted (and presumably useless) mixed fuel from the tank and then dispose of said contents. And... am I right in thinking that, once emptied, simply filling the tank to the top with diesel the engine will run okay?
Thanks in advance.
Fortunately she re-engaged brain and noticed her mistake before trying to drive off so when I got there we towed the Surf home. (Fortunately I had the works Nissan Navara so towing the Surf wasn't really a problem). It has NOT been run - or even turned over - since her little faux pas.Question is: how do I get the unwanted (and presumably useless) mixed fuel from the tank and then dispose of said contents. And... am I right in thinking that, once emptied, simply filling the tank to the top with diesel the engine will run okay?
Thanks in advance.
