I am in the process of organising a lift for the surf, currently I am torn between a 10, 13 or 17inch lift with a 4inch bodylift. At the moment I am in the mind of "if I am going to do it may as well do a proper job!!". What are peoples thoughts to the lift and size?
I currently run 33inch tyres (i think) and I fully expect I will need bigger as the car may look silly. Opinions would be good though.
I could do with some advice on problems associated with lifting surfs, is there any un expected costs/problems that I have missed as it seems quite a simple process.
This is a project which I have spoken extensively to L A Supertrux and I am pretty sure they will do the work.
Any advice or thoughts would be good as this isn't a cheap process and I would like to iron out any potential problems before I start.
Thanks
James
Thanks
James
