front rattles
  • front rattles
    the front of my surf rattles when i go over the smallest of bumps.
    it also happens if you are going slow in say 1st gear and you lift your foot off the gas, it rattles and then again if you give it more gas.
    are these the things that i need to sort the problem.
    cheers scotty
    check your rubber bump-stops which hang from upper wishbone,
    took me ages to find my rattle.....
    carl....
    gettin coooooler... and dark....
      cheers mate,
      will check these out before i go down the line of those brass bushes as they are a wee bit deer.
      cheers scotty
