My rear is not at all well
I have a clunk on the drivers side rear, looked under and all i could see was a snapped ARB bracket and a loose nut on the towbar. Anyhow i fitted the new mount and tightened the bolt and went for a test but alas it was as bad as ever.
I just cannot see anything obvious but if the suspension has to work at all then i get the clunk, are there any common issues that manifest themselves in this way? Cant see any bush problems and am a bit lost.
Any guidance is greatly apreciated.
.I have a clunk on the drivers side rear, looked under and all i could see was a snapped ARB bracket and a loose nut on the towbar. Anyhow i fitted the new mount and tightened the bolt and went for a test but alas it was as bad as ever.
