Front Brake Hose 3rd gen help needed
  • Front Brake Hose 3rd gen help needed
    Need to fit 2 new brake hoses for MOT, Anyone know whether they are compatible with landcruiser or where i can get some from ASAP - In a bit of a rush left it till last minuite as usual Model is 3rd Gen 3.0 Diesel Auto KZN185
    Thanks for any help Gary.
    Get a couple made at a local motor factor for o few quid each. Most decent factors make brake hoses and lines up, some while u wait.
    Al.
    I used to have a surf me!
      are you on about brake pipes or brake hoses?
        Most places will make up the flexi hoses, and quite a few will do the metal pipes as well.
        HTH
        Peter
        I am not a number. I am a FREE MAN!
          If its the flexible hose, the p/n is 90947-02862 (same p/n right & left) and its the same one fitted to the landcruiser 90/prado from 04/96 to 06/99
          Maurice
            Please can someone point me in the direction of a motor factors that can cos i just generally don't get much help at all from most of them!! It would be great to find a good one.
              cheers morr
                Both,
                good ones can make any hose or pipe u need.
                I used SAS in Harrogate last time I had some made but any factors ought to do you and if that does not work talk to a mechanic at a back street garage as he will have contacts in your town.
                Al.
                  And they're £40+vat EACH!!! Only really short ones as well!
                    Thanks a lot for all your help - I asked toyota for a price and they said they were £47 each inc VAT. Being a bit reluctant to pay that much I continued to shop around and managed to get the exact right ones from bluepoint for £10 each - good quality ones as well. Havn't got the part numbers right now but I have got the packets in the garage if anyone wants them for reference.
                    Thanks again, Gary
                      Just dug the old packets out of the garage whilst clearing up - the brake hose part numbers from blueprint are ADT353185
                      you can find your local distributor at this website. www.blueprint-adl.com
                      Hope this helps a couple of you at some point. Cheers, Gary.
