I'm fed up with my toy town 2ton cheapy jack and axle stands, hardly gets the wheels off the ground so you can guess the fun i had replacing my rear coils yesterday
it was a bricks and wood blocks job and bunging anything else i could under there in case that should fail, and i still had to go get some coil compressors, not good, guess this low end stuff is for normal cars, so i'm thinking i need some better gear
I found this - http://www.machinemart.co.uk/product.asp?p=020110311
It's rated at 2 tonnes but has a max saddle height of 800mm for £130
And these axle stands http://www.ccw-tools.co.uk/catalogue...1437&cat_id=29
with a max height of 758mm for £56
Is that the best i can do for that price range? That jack seems cheap for the height, is Clarke stuff ok?
it was a bricks and wood blocks job and bunging anything else i could under there in case that should fail, and i still had to go get some coil compressors, not good, guess this low end stuff is for normal cars, so i'm thinking i need some better gear I found this - http://www.machinemart.co.uk/product.asp?p=020110311
