Problem solved!Blocked breather valve,wrong diff oil.
leaking brakes
wrong oil! is your diff limited slip? if it is and has the wrong oil in it it will destroy it. after a week or so check to see if the seals are still leaking, if so have them change the oil seals.Originally posted by RobDProblem solved!Blocked breather valve,wrong diff oil.jim.b.
1990 SSR LTD 2LTE auto
1985 SR V8 4.4 litre manual
The diff is not limited slip as far as I am aware(please correct me if I'm wrong,1996 3rd gen,manual transmission)the problem with low speed lock ups has gone since the diff oil has been replaced.No leaks were found behind the brake drums or on the axle.Originally posted by kiwi-jimwrong oil! is your diff limited slip? if it is and has the wrong oil in it it will destroy it. after a week or so check to see if the seals are still leaking, if so have them change the oil seals.Powered by ????
