oil leak from diff
  • oil leak from diff
    I developed an oil leak on the front diff on the short side.
    Has anyone had this problem and whats involved in sorting it out.
    ScubaSurf
    The place to be is under the sea
    no biggy, drive shaft off, pull out gear shaft (may need slide hammer, or two pry bars, its held on to the spider gears by a small clip. Not sure how much space you'll have leaving the diff in the car), pull seal, then punch in new seal, then gear shaft (shop manual recommends a new clip. Check there is 2 - 3mm of play in the axle direction, then check that the shaft will not come out by pulling by hand) and Bob's your cross-dressing aunty!
    Job done!
      Job done!
      Thanks Tony Yours a star.
      I had visions of pulling the the diff out and stripping it down. I like these surfs. there not to scarry to work on.
      Robin
      ScubaSurf
        ment to post this as well last night, but forgot! doh!
