how much "play" should there be in the rear diff? ie how much slack should there be when you turn the rear prop with both rear wheels on the ground?
mine seems to have a fraction under 1/2" of movement when measured at the nose of the diff (pinion bearing cover)
is this a bad thing? if so how bad? (bad enough to need a new one,possibly locking?)
disco now gone aswell
