Hi can anyone tell me the biggest tyre size you can put on a Mk2 with changing the suspension.
Wheel size
Someone will correct me if I am wrong but I am sure that 31 inch tyres are generally the largest tyres you can get on standard suspension.Originally posted by markus iowHi can anyone tell me the biggest tyre size you can put on a Mk2 with changing the suspension.
With a small lift on the back (1.5 - 2 inch) and the front torsion bars cranked a bit you can get 32's on.
Rich.If life's an uphill struggle then downhill from now on can't be that bad?!
