wheel geometry
  • wheel geometry
    hi guys just been trawling tinternet trying to find the actual wheel alignment figures ,i have looked under 4/runner cant find anything ,can any body pint me in the right direction,mines a 1997.i have found a bloke who rekons he can do it with the rack of his eye?? a lot of laser firms need the data to input b4 they can reset it.im doing this ready for when i fit my lift kit and stuff
    hey just got a new 30 td surf all the gadgets 1997 metallic black niceeeeeeeeee
    Is this any good?
    All thanks to 'Greebo' for the info.
    http://www.hiluxsurf.co.uk/forums/at...chmentid=15137
      Is this any good?
      ah thanks man ,but ithink thats for a 1993 surf probably different on a third gen
        Hi Gaz..I believe a few owners of 3rd Gens have used these stats.
        Gaz
          This thead kept coming up when i was lookinghttp://www.yotasurf.co.uk/forums/showthread.php?t=15156
          www.daemon4x4.org
            Good one that man...been trying to trawl through my techie info for this. Knew I had it somewhere.
            Gaz
              hey thanks i did see that b4 but didnt take much notice.
              looks like that will be ok to use for mine.thanks again
                have a look in ATS... it's the same as a landcruiser Colorado so they'll have the figures there.
                  hi man my local ats dont have the facilitiies to do a 4 wheel geo check ,however i called my local toyota dealer and they could/might be able to for 60 quid.
                  so you are saying that the colarodo is the same as the 3rd gen surf?
                    Your toyota stealership should know the specs. I had mine done by a local garage and didn't know of settings...evrything seems fine [believe they did a full geometry set-up after I knackered by front idler up]
                    Gaz
                      These settings are for a 93. Will these be the correct setting for the 95 2nd gen too? Thanks in advance guys.
                        yea just get the same settings as the 4runner Clay.If your going to the place down near Maynes garage then they will know exactly what to set it all at
                          http://forums.bauchan.org/4x4/topic.php?id=73
                            Rich, spoke to taylors today. They told me they dont do it anymore. Told me i got to go to falmouth tyres, got it booked in 1st thing thursday.
                              a place like taylors and they stopped doing the alignments.What do they do when you buy tyres and have them fitted there?i take it they fit the tyres then send you to falmouth,what a bunch of ######s
