I've got a slight oil leak that is coming from R/H side of the engine as you look from the front , about the same height as the fan but a bit further back
If it coming out between the block and the head, where the engine number is, then its pretty common. To be honest, if its not dripping over the floor, and is just a little wet, its really not worth the effort in taking the head off and changing the head gasket just to fix it.
I'd leave it be, at least untill it gets bad enough to warrent doing the work.
