how easy is it to fit a lift kit, and how much will it cost for the bits pleeeese?
You really need to let go of a bit more detail if you want the best advice.
Like why you want to lift it, for looks, for clearance, to fit bigger tyres etc etc.
Do you want a body or suspension lift or both or do you care?
How high to you want to go?
Will you be doing it yourself?
Any backround info as to the reason for the desired lift will help others to help you.
