Fuel pump seals-diy
  • Fuel pump seals-diy
    Has anyone replaced their diesel fuel pump seals themselvs? mines leaking and local diesel places dont seem to have much of a clue.
    cheers
    Ray
    You dont need to remove the pump as in this write up, but it will give you some idea of what's involved. http://www.toyotasurf.asn.au/techsite/fuelpump.htm
      cheers
      Ray
      Hi,
      I did once take a diesel fuel pump (from a previa) apart when I had a repairshop of my own (1990 - 2004 )...and could only get the two O ring seals in quick time for the owner - he was booked on a ferry out of Rosyth... Not an easy task if you are not specialisin in diesel pump maintenace... they are a lot differnt from the usual robert bosch pumps, or lucas (cav) etc.. BTW I succeeded and it cured the leak...But later discovered there was major internal wear of a component and some spring needed replaced, it was done via a spares part exchange deal.. So, unless you have experience and used to working with small parts AND can retain the vehicle's timing.....Get someone else.IMHO
      Peter
        i jet washed the whole area took off the n/side fr wheel even bought a new posh little torch,i cant see the bleeding leak i think its over to the pro`s the only prob is that anyone within spitting distance dont want to touch the efi type pumps. i have a no. of a friend who services his surf so i will give him a go first,i`ll keep you posted
        Ray
          Ray.
          There is a diesel pump specialist in Watford,
          Diesel Fuel Injection Services Ltd
          Unit 14 Peerglow Ind Est Olds Approach, Watford, HERTFORDSHIRE
          Tel: 01923 721194
          They will do a rebuild for you.
            ta very much Andy I will let you know how i get on, Ray
            they will have a look tommorow,my wallet is groaning
              When i got back off of the floor the cost was............ approx 1 day at £40 per hour to remove and refit pump(14hr days)
              £400-500 for the pump rebuild + possible replacement of the spill valve(whats that??) @ £180ish all plus vat of course.
              Looks like a future without surf.
              any ideas? is there a recon pump place that may be cheaper if i remove and refit the pump my self? failing that any one got some matches???
                any ideas? is there a recon pump place that may be cheaper if i remove and refit the pump myself? failing that any one got some matches???
                Try Wade deisels in Hoddesdon, they are good with Surfs, Leaks in the top cover are pretty easy to sort, I've done a couple for people now.
                  pump seal replacement
                  ive just ordered a new seal kit to the pump from a 92 2.4 surf. on inspectin this was not leaking from the top cover but somewhere underneath or as close to the engine block as possible so you cant view it from the top nor anywhere else it does however leak when cold and stops once warm so it looks like those seals are gone.
                  it'll be a slow progress but ill do a full photoshoot for those interested.
                  hope to help
                  marc
                  3.0td 4runner and 2.4tdsurf
                    best(worst?)prices so far
                    watford £4-500+vat for the rebuild+£40+vat per hour up to 14hrs +possibily a spill valve at £180
                    s/h pump from low milage car £150
                    another from bennets pump rebuild and test from £150 to £750.
                    if i confirm the s/h pump low milage and warrantied etc can i just remove the old one and making sure the pump timed the same and in the same postion on the block is this my best option?
                      check out my post mate
                      http://www.yotasurf.co.uk/forums/showthread.php?t=17854
                      http://photos.yahoo.com/boaby57us
                      i done my seals myself as i was PI**ing fuel
                      let me know what you think
                      markieboy306@hotmail.co.uk
                        Awesome pic`s tigger, now i just need the time and i`ll diy it. Thanks your braver than me
