ive got a 92/93 k plate surf with an overheating probblem which is a common problem so im told. can anyone shed a little light on this subject???
over heating on my 2.4
do a search for 2.4 head and you will know all..Originally posted by mels boyive got a 92/93 k plate surf with an overheating probblem which is a common problem so im told. can anyone shed a little light on this subject???
The overheating problem is well known and documented on the 2.4's... when they overheat they are 99.9% likely to crack the head.. When this happens make sure you get a new "modified" one.. that should be a near perminant solution.
what exactly is your "overheating problem" - it may not be the head could be somthing relitavly (i think thats spelt wrong) simlple.
Put up some more details about exactly whats wrong and your bound to get some answers from the wealth of knowledge on here!
JoeParanoid? They're out to GET YOU!
2.4 + Overheating = Cracked Head.Originally posted by joe112
Joe
Thats all the details we need!
Not nessessarily??? if it has already had the head done and is the mod'd one it could be somthing different.. mine was always overheating a while back and all it needed was "burping"
Originally posted by joe112Not nessessarily??? if it has already had the head done and is the mod'd one it could be somthing different.. mine was always overheating a while back and all it needed was "burping"
Joe
Just playing the odds, with the details that where available in the post.....
You already blagged the sensible answer, so flippancy was all that left!
