Hi Folks
I ve just changed the timing belt on my 2.4, it is a bit of a sod to do, as you have no access from underneath unless you want to remove the A/C cooler and pipework other than that it wasnt to bad. If I get time I ll do a write up on it and post it.
The test will be in the morning to see if the timing needs advanced a little bit. I ll find out and let yous know.
Cheers Charlie C.
Cheers Charlie C.
