Shaking getting worse again in the truck.
I replaced idler arm BUSHES last a year June,
so have ruled out the idler arm as a cause since and never looked at it, when checking for steering component wear.
But tonight on having another shake of wheels, I noticed the end of idler arm (at ball-joint end), moved up-and-down noticeably around 1-2mm as well as side-to-side.
How much up-down movement have people noticed on worn idlers?
Would this movement be enough to effect vehicle and cause shaking and imprecise steering ?????
Doubt I will replace bushes, as they have only lasted 15 months,
and the idler arm was a bit rusty inside when i changed them.
So looks like a roughtrax idler, as dont fancy taking a chance with the cheaper Milners one...
Hopefully this will help get rid of shaking! as i just fitted a procomp HD steering damper too.
