I'm looking for a 12v thermostatic switch.
But not the type you would normally expect.
I want one that switches OFF when temperature meets a pre-defined temp e.g. 70 degC. I have looked on http://www.vehicle-wiring-products.co.uk
which is a useful site -
but they only have the normal type, where the switch activates, goes ON, at a set temp - e.g. to turn on a cooling fan.
basically i want the switch so it switches OFF a fuel line heater, when the coolant gets to a good temp, and heat exchanger takes over heating fuel.
