Started the 2 1/2" spring spacer fit yesterday, got the rear done pretty easy, got the front struts out without much stress by removing the bottom ball joint via the 4 bolts. Fitted the spacer kit to the struts ok came to re-fitting and can't get the bolts back in the bottom ball joint
Have tried trying to get it lined up with jacks & big big bars etc but can't seem to get it any where near, is there some kind of easy way that i have missed ? Was working on my own (billy no mates
Did this yesterday on my own after a 12 hour night shift & gave up in the end returning the front struts to normal and re-fitting which was easy getting the 4 ball joint bolts back in.
Truck now looks like a drag racer...........cool
)Did this yesterday on my own after a 12 hour night shift & gave up in the end returning the front struts to normal and re-fitting which was easy getting the 4 ball joint bolts back in.
had another go without tired eyes and did it quite easily utilising coil spring compressor, trolley jack and bigish tommy bar.
