Hi, after a sudden loss of power the other day, I have now got smoke billowing from the engine conpartment. On closer inspection I've found the three nuts holding the exhaust onto the manifold, are missing! Does anyone know what size they are and how best to replace them as they're a little in-excessable.
exhuast manifold nuts and bolts
If its a late 2nd Gen...
The gasket is:
90917-06041
The nuts are:
90179-10070
From your friendly neighbourhood stealer.
The nuts are split nuts to encourage them to stay locked on... if they are loose, them someone is likely to have had a go previously.
Side cover to access the oil filter... have that bit off... some access... but easiest is from underneath, from the gearbox... with a couple of extensions, with a flexi joint.
1990 is a G reg 1993 is a K regOriginally posted by trekjockThe car's a 1990 K reg, if thats late enough. I think I know where you mean regarding the panel though. Thanks I'll give it a go!!(\__/)
Mac The Wac
