The last few days my brake warning light has been coming on dimly, I checked the brake fluid, it was on the low level so topped it up, the light went out, but has since been coming on every now and again, any ideas, the front pads seem ok and not to worn.
brake warning light
you could have a dodgy connection on the fluid level plug, check that, also check the hand brake light switch is OK, its under the dash on the lever.
Failing that, its also a warning that the vacuum pump is playing up.4x4toys.co.uk - Keeping you on and off the road...
i had that last weekend topped it up & friday it was on again fitted new pads today easyiest pads ive ever changed 10 minute job. pads were on the the borderline of bare metal £12.50 from milners(\__/)
