Surf Wheels
    Originally posted by joinerman
    Right i tried this today Small gear lever right back in H 4wd button out ie nothing illuminated on the dash plant your foot & it wheelspins on all four wheels, If you press the button on the stick it does make a click behind the dash & illuminates Any ideas?
    Brian
    it doesn't wheelspin on all 4 wheels!!
    unless you've got diff lockers and 500hp!
      Brian
      If you can 'spin' all 4 wheels and you're not in 4wd, then it's either a vacuum or solenoid problem!
        you wouldn't spin all 4 even in 4wd.
          I said 'spin'
