I have a cunning idea
My AC is low on pressure but does still have gas in it and oil, that much I do know
It is the older type with the small valves on the compressor so I assume that it runs R12 which no one round here wants to know about. All the automotive AC people are telling me blah blah blah $600-$800 to get it up to R134 spec.
B@llocks to that !!!
Now here is where I my plan comes in.
The valves are a standard schraeder (spelling ?) type.
Can I bump up the gas pressure with AIR ?
If so what would I pump it up to and which of the two valves on the compressor do I poke the air into.
Waiver for those giving advise
At present my AC is as useful as t1ts on a bull
If I cock up this process and poke my AC system I am not really bothered as it can not get worse. I’d probably just rip the whole lot out and be done with it.
I am looking for a low/no cost solution here.
.. i had same problem with r12 garages telling me this and that , and then the usual turning there lips into a flut before blowing the words it'l cost a few quid??.. well '' heres my solution '' r12 isnt obsolete it can be used i know i have located the gas '' however it isnt cheap '' i found a replacement diy kit called iscoen r314 drop in replacement for r12 ( not r134a ) it comes in a kit with all the attachments for your car .. about 56 quid and your done '' mines as cold as the chest freezer at home ... just dont always take in what you hear its better to research than just do what the so called experts say
if at first you dont succeed..... bollock
