confused
  • confused
    I went off road today and when i got back i hosed the surf down.When i was cleaning underneath i came across this, can anyone tell me what it is off or where it should be.
    Is it metal or polyurethane?.....obviously looks like some bracket and could be some separate with your being lifted so high!
    Gaz
      [QUOTE=Gizmo]Is it metal or polyurethane?.....obviously looks like some bracket and could be some separate with your being lifted so high![/QUOTE
      This is plastic, but when i think about it this might not be of my surf it could have come of somethink else as there were others there with Discos,fronteras and zukis.
        probably just something you've picked up... have agood look around and if nothing seems out of place then i wouldn't worry!
          it looks abit like the plastic bit that goes over the axle for the u bolts to go over to bolt up the leaf springs on a zuki
            [QUOTE=mattys surf]
            it,ll fell of one of them no doubt
            ship
              I have had a good look underthe surf but cannot see where this might have come off,so i think i must have picked it up probably from one of the water holes, i hope!
