Try a search for front wheel bearings as I think there is a writeup on here somewhere on how to do it.Anyone got a link???.Now I'll explain why I said wheel bearings.You will need to know how to do these because the hub and disc are assembled together and needs removing to seperate the disc from the hub in order to be able to replace the studs.Mark the disc and hub so you can assemble the same way just in case the balance is upset.Have fun.
You need to remove the whole hub assembly then split the disk from the hub.
There are about 6 bolts that hold it all together then knock out the old stud.
