brakes
  • brakes
    after last weeks brake pad change i'm now coz on a run up in the hills on sunday,i noticed an awfull smell coming from the front wheels and the amount of brake dust is silly( wheels very hot at bottom of big hills but cold on normal roads). since pads were done i've covered about 400 miles, when i did the chage i did de glaze the discs and copper slipped the anti squeal/rattle plates and freed up the pistons.
    i'm cosidering taking the pads back coz at this rate my discs will warp
    old pads used to heat wheel up but not like these plus no smell or brake dust
    any advice from you ever helpfull bunch
    p.s. any idea cost and from were i can get injectors and do they need setting up or are they like glow plugs
    john
    where are they from ? are they toyota ones?
    Tony just changed mine, I had toyota pads on which never gave any dust off - the new ones do more but not really "tried" them yet
    Not noticed any excessive heat though.
    Tim
      sorry i forgot that bit
      they are lockheed pads from ces motor factors.
        john
        Mine did the same, and i had my disc's 12 grooved as well. They seem fine now and i also was worrying about overheating.
          john
          UK cylinderheads where doing recon-ed injectors for about £120 (+vat and p&p) They just screw in, no setting up needed.
            thanks guys for the replys
            i'll give the pads a couple of weeks incase they need a lot of bedding in.
            tonyN thanks again i'll give them a try, have you any contact details for them????????
              If the pistons are sticking badly then you may not have pads in a couple of weeks.Keep an eye on them and if they continue to heat up then it's caliper rekit time.
              Neville
                or new calipers as I need...
                list to do: calipers/injectors/heater matrix fitting/aircon rad fitting and gas....
                Tim
                  injectors
                  hi
                  just had mine re conned by Lucas in Plymouth now called LSUK and are nation wide - look nice cost £98inc
                  tony
                  Tony
                    Originally posted by fatfires
                    hi
                    tony
                    got lsuk locally will give them a go
                    pistons not sticking as wheels run cold normally the hills i was talking about are proper ones (north wales is were i live)two miles down hill hence why it's play miss the mountain biker at weekends
                      im sure dieselBob said he needed the injectors to recon / replace them?
                      I guess thats what you guys have done to put up without the Surf for a couple of days?
                      Why oh why then is the labour £100's to get done - is it a pain in t' boum?
                      Tim
                        this weekend i will be phoning around to get some prices
                        i will post the answers on here if i get any
                        name and shame is the name of the game
