Reesky
  • Reesky
    OMIGOD. I had that water pump replaced and now the turbo does'nt come in.
    Ideas???????
    Relax, Then check the small vacuum hose that runs across the engine, it fixes either end of the pipe with "DIESEL EFI" on it. If not, look at the air cleaner, on the back side there is the Turbo pressure sensor, check its plugged in, then follow this pipe across to the intake elbow, where it goes though a little filter/valve, then down to the intake manifold right under the throttle flap housing.
    Assuming you have a 2.4, I'm not psychic! Fill in you user profile a bit!!!
    http://www.yotasurf-online.co.uk/pub...do=editprofile
