Lowering to original height
  • Lowering to original height
    I've just bought a 96 KZN185 and i've been told I will have to lower it to the original ride hight for the SVA....
    anyone know what the original ride height should be... at the moment the front is 54cm and the rear is 60cm (heights are from the centre of the hub to the lowest part of the wheel arch)
    I'm guessing I will have to replace the springs front and rear.
    Is there anything else I will need to replace...??
    ty
    [CENTER][img]http://www.danasoft.com/sig/bolloxx.j
    Who told you that??
    Chances are that unless it outrageously lifted they will not even notice and bother to measure. Then they have to have Manufacturers specs to compare with.
    I know I am over here in sheep land but I figure that vehicle inspections can not be too variable.
    Maybe wait for some answers from the locals first
    Simon.O.
    '90 SSR Ltd 2.4TD 5 spd
