Hi all.
I’ve a question regarding my 1995 SSR-X 3.0 turbo diesel (KZN-130)…
Does anyone know if the front and rear diffs on this model are interchangeable (assuming ratios are the same, of course)? I know that you can physically fit a rear diff into the front but is there anything specific to either of them to suggest this wouldn’t work correctly?
Reason I ask is that I’ve just had my front diff replaced(due to shot bearings, apparently) and the replacement unit is a rear diff from the same model/year, suitably refurbished and with same ratio as the rear already on my Surf.
Although 4WD mode and everything else seems to be engaging properly and working fine, the front diff does “wind up” a great deal when the steering’s on full lock. That may be normal but I’m just checking to make sure…
Any info would be great! Ta.
