info on servicing surf
  • info on servicing surf
    just got me a surf im told there easy to service, is it worth doing it myself or is there a specialist about who doesnt fleece you ?
    any info on self service or cheap mechanic would be greatfully accepted
    also just got a good deal on radio frequncy expander from
    merlin productions(uk) cheltenham ! £15 + pp
    mail me craig.boyd1@btopenworld.com
    thanks
    Hi and well done for buying a Surf,
    Oil change is dead easy with full lock on there is access under the wheel arch to the filter, but it is behind a splash cover, and the drain plug is one of the easiest to get at mainly due to the enormous ground clearance.
    Air filter is also a piece of cake, just a couple of clips.
    Fuel filter is a bit hazardous check out the threads on that one, seems there are problems bleeding air from fuel system!
    I could go on but there is loads of info in the Tech section, have fun and await your head going...
    How much!
      how bizzarre! my oil filter is accessed from above!
      rhs of engine
        Hi Craig,
        It is easy to do a service as mentioned above.
        You will find a wealth of info here.
        I have sourced parts and Milners are definitely the cheapest.
        You have'nt given any details of your Surf. I may have seen you around town.
        Ian
        One day my paranoia will go away!
