Any one have any experience of problems on the front hub driveshaft bushes. I dont have any excessive movement that I can find, but I do get an intermittent howling from near side or off side or both at times. Cold temperature makes it worse. A US 4runner site says its a known problem at cold temperatures and that a Toyota upgrade was/is available as a needle roller conversion using parts:
90364 30011 needle roller
90381 32001 bush
I have new bronze bushes etc and will be replacing them soon, anyone done this already and know the correct grease to use, any way to re-grease them without stripping the hubs down.
cheers
90381 32001 bush
cheers
[SIZE=4][FONT=Century Gothic]I can fix it...it won't be cheap.........or pretty![/FONT][/SIZE]
