can anyone help with a cam belt change ? i want to change the cambelt on my 1991 surf but i have not a lot of money and a great distrust for garages would anybody (who knows how to do it) like to help me change the cambelt there are beers and food and lots of gratitude for the machanic who helps me im in coventry i can travel and im free any weekend if you can help e mail me at matthew@mat02.fsnet.co.uk many thanks matt
As far as I know the 2.4L cambelt change is a more difficult job than on the 3.0L so I'd be reluctant to tackle it myself.
I did however find a local garage who can service Surfs:
http://www.southwarwickshireautos.co.uk/
Might be worth giving them a call?
Nevillef
Most difficult part of changing the cam belt on a 2.4 is getting the bottom pulley off. Next most difficult is lining up the timing marks and getting the belt on without them moving (the injector pump is sprun right at the timing point).Originally posted by laser_jock99As far as I know the 2.4L cambelt change is a more difficult job than on the 3.0L so I'd be reluctant to tackle it myself.
Nevillef
Apart from that it's easy if you go at it slow and methodical, about 4 hours work for a newbie.
I'd help as I have been off work but I'm starting a new job tomorrow and weekends are pretty much a no-no at the moment - too much on.
That is easily overcome by having the crank timing mark a tooth out to the left.Put the belt on,release tensioner,turn crank till timing mark aligned and it should be spot on.Works for me but ALWAYS recheck timing marks after tightening everything and rotating crank a couple of times.Originally posted by luckyNext most difficult is lining up the timing marks and getting the belt on without them moving (the injector pump is sprun right at the timing point).
Neville
They have a couple of Surfs in stock- never noticed if was always the same two! Hope their mechanics are better than their web site....can't bring up the stock list at all!Originally posted by Chillittthey have had the same 2 surfs in sock for 6 months.. wonder if they will haggle...also they have just got new management
It would be nice to find a local garage that knows a bit about Imports though.
Nevillef_________________
Nevillef
looks like they have sold the 2.4. i went down once- its only down the road, wandered round kicking tyres and looking hopeful, couldnt flush anyone out to talk to....still new management now, might try again. their sites been like that for ages. doesnt inspire, but worth a look i 'sposeit's in me shed, mate.
have you used this garage are they any good?
i was hoping someone from the forum might do it for me i know a few mechanics but it runs so well now dont want a first time surf mechanic messing it upOriginally posted by laser_jock99As far as I know the 2.4L cambelt change is a more difficult job than on the 3.0L so I'd be reluctant to tackle it myself.
Nevillef
Just how far are you willing to Travel??? I'll give ya a hand
But seriously you CAN do it yourself. Like the others said just go slowly and methodically.
There is a great write-up on the Aussie site that I followed and it was easy.
Hot tip: Pull the radiator out, it gives you heaps more room and a good oportunity to check and clean it.
If you are half handy with tools it is 4 hrs work plus a couple of cans
Have a look here:
http://www.toyotasurf.asn.au/techsite/timingbelt.htmLast edited by simono; 24 February 2005, 22:23.Simon.O.
'90 SSR Ltd 2.4TD 5 spd
