...so ive been thinking of these up and coming green laning trips and salisbury plain. so i though at the weekend id try out my diff stuff and the 4x4 properly. i have not ever seen my 4x4 warning light come on and i have tried in the past!!!
i found a suitable 400 yard 'greelane' up on woodbury common and engaged 4x4. i then proceeded along but of course it was nothing that the truck could not handle anyway. at the end was a short steep incline. ahhhh, i thought, this is when ill find out if it works. with o/d off, 4x4 engaged, i slowly approached the muddy incline. almost immediately the back wheels started spining. i could see that the front wheels were not driving at all.
i reversed back down and did a bit of backward and forwarding in case the 4x4 needed a bit of engaging! i then put it in low ratio and had another go at the incline. same again!???
my tyres are b/stone dueller a/t's and are semi worn but still got reasonable tread.
to top it off, when i reversed, i smashed my fog light off!
AM I DOING SOMETHING WRONG OR IS THE SURF DOING ME A WRONG!!!
ANY SUGGESTIONS WOULD BE WELCOME.
ill pick them up in a week as im off away.
.....and yes, ive no doubt it does say somewhere on a previous thread but id be there years and im in a rush as it is....(sorry, im not been rude)
mat
mat
