I promise i have searched before posting this!
There is something i can't understand about the 4WD system on my surf which I'm hoping someone can put to rest -
All agree that you shouldn't use 4wd on the road or you'll get transmission wind-up and snap a shaft etc. But most people seem to say that the Surfs don't come with locking diffs as standard. So if the diffs are not locked why would you get the transmission wind-up?
The way i understand it is the front diffs are always open (so same as 2wd car)
some Surfs have LSD rear (but even still they can slip so no transmission wind-up there....)
Is it the center diff that is locked?
In normal driving mode I've got 2wd at the rear, if one wheel spins i stop. I put it into 4wd, does that lock the rear? No? Then if one front wheel spins also will i still be sitting there like a pillock?
If the diffs are not locked why would there be transmission wind-up?
Sorry guys i know it's an old one but i just don't think i got it yet
Neil
Neil
