Before I go off on rant to my supplier about cheap, Chinese bearings- can anyone think why a new rear wheel bearing would fail after less than a month? It's a bearing I installed 27th December- and I've done no offroading since.
I pulled out the offending bearing last night and it is badly worn. Trouble is that powdered bearing material has gotten past the diff seal and into the diff. I've flushed out the diff twice with new oil and will probably do it a third time at the weekend.
I have now installed an English made bearing in the hope that it might last longer than a month!
So what might cause a bearing to wear out so quickly? What supports the other end of the halfshaft- could this be worn? Are there any 'tracking' issues with rear wheels I need to be aware of?
The bearing on the other side, intalled in October, but from another supplier appears fine.
Your thoughts please.
Nevillef
Nevillef
[SIZE=4][FONT=Century Gothic]I can fix it...it won't be cheap.........or pretty![/FONT][/SIZE]
