fault codes
  • fault codes
    Anyone got any info about ecu fault codes on a 1990 2.4 td ( not efi ) glow plug flashes 4 times when diag terminals bridged.
    Cheers Steve.
    STEVE check some of the AUSSIE sites.
      Stevo.
      Koi and I are going to look and see if it has anything in the Max Ellery Manual. Are you sure that the code you have isn't the coolant sensor to the Glow plug timer?.
        codes
        Thanks for the reply and for Nigels call, in the process of sussing out which sensor might relate.
        Cheers Steve.
