I have a 3rd gen ssrg and i find the suspension really hard! the difference between hard and soft is minimal, yet on my 2.4 ssrx there was a big difference, soft was nice and comfortable while hard was what it said on the tin! does anybody else find this?
ssrg suspension
Are you sure they havnt been changed for uprated ones? If you have adjustables, they are actuated by small motor units on top of the shock. If you open the window, you should be able to hear them working. Alternatively, you should be able to see a moveemnt on the voltmeter as they go on and off load.Originally posted by riddlerI wonder if mine is stuck in 'hard' , god, how the hell do i find out about that?
Having said that, the difference on mine is not all that great - really just a more fidgety ride when set on hard. I tend to use it only for motorway (to improve stability in case of quick lane change) or when offroading to give a little bit of additional resistance to help the springs. Mostly I like to wallow around on the std setting.
Kev
suspension
Iwill check to see if i can hear anything happening, there is'nt a volt meter to watch mores the pity, i wonder if its just me, and that is how it is supposed to be! my 2.4 was torsion bar and this one is coil over shock. It just seems too hard on normal.
Thanx for the reply.
Paul
I've ridden in both 2nd and 3rd gen - not that much difference in the standard ride. My bet would be that the shocks have been changed out for procomp or some such.Originally posted by riddlerIwill check to see if i can hear anything happening, there is'nt a volt meter to watch mores the pity, i wonder if its just me, and that is how it is supposed to be! my 2.4 was torsion bar and this one is coil over shock. It just seems too hard on normal.
Paul
Linda
www.4x4toys.co.uk
When looked at my electric adj shocks I found at least two were malfunctioning. So I took them all out and put some decent Pro Comp offroad ones in- never looked back since. By the way- Toyota price for a replacement is £186 each +VAT. Pro Comp ~ £30 each.Originally posted by riddlerI have a 3rd gen ssrg and i find the suspension really hard! the difference between hard and soft is minimal, yet on my 2.4 ssrx there was a big difference, soft was nice and comfortable while hard was what it said on the tin! does anybody else find this?
Nevillef_________________
Nevillef
http://www.supertrux.com/Originally posted by riddlerwhere can i get procomp from?
or
http://www.toyotahilux.com/
or
http://www.explorerprocomp.co.uk/Linda
www.4x4toys.co.uk
suspension
I'm in sunny stourbridge!! I think i may end up changing the shocks and the springs, because one of the rear springs is sagging and the ride is just so hard it spoils the truck. Just need to look into it a bit now, don't think i need uprated springs just standard with some nice new shocks that work!
Thanx for the replys all
