Well looked out the window this morning and saw that it wasn’t actually raining so I thought I would grab the grease gun and get the Surf greased up and have a general rummage around. I noticed that there was a bit of play on the rear prop shaft, it will rock back and forwards half an inch or so, is this normal. I also found that one of the front drive shafts is as loose as a really loose thing (it almost feels like it is going to drop out of the front diff). Has anyone else had this problem and is it going to break the bank.
