My 2.4 ssr-x refuses to grip the road when trying to set off in the wet. I am not trying to set off fast but the back wheels just won't grip.
The only things I can think of are the shock absorbers (one is damp) or the tyres.
The shock absorbers have the electrical adjusters ( £130 each for new ones
) but i am wondering if they can be replaced with ordinary ones ( £35 each
) . Does anybody know how the balance of the car will be effected , will it effect the ecu (i've been told by a toyata dealer that it will effect the ecu but i'm not convinced), would it be dangerous to have adjustable shocks on the front and ordinary ones on the back.
It has yokohama tyres with plenty of tread. I've tried letting the pressure down from 30 psi to 26 psi but thats not made any difference.
Any help on this matter would be greatly appreciated.
Thanks in advance.
) . Does anybody know how the balance of the car will be effected , will it effect the ecu (i've been told by a toyata dealer that it will effect the ecu but i'm not convinced), would it be dangerous to have adjustable shocks on the front and ordinary ones on the back.It has yokohama tyres with plenty of tread. I've tried letting the pressure down from 30 psi to 26 psi but thats not made any difference.
Thanks in advance.
. To prevent, just start a little more gently until it has got into 2nd gear obviously.
A positive attitude wont solve all your problems but it will annoy enough people to make it worth the effort!
