head or gaskit?
  • #16
    worried
    You now have me worried, the light is a small rectanle in the middle of the speedo, and there is a small picture of a turbo above it, if it is not the turbo but a fault detected by the ecu what could the fault be ? it is not on all of the time,
    Richard
    • #17
      Richard
      Richard.
      Sounds like it could be a turbo light, however are you sure that the picture is not a small picture of an engine making it an engine check lamp. I think I'm right that all the 3 litres even 4 runners didn't have a Turbo light (which is green by the way on the 2.4) however someone may put me right on it.
      • #18
        Hi Phillipe.
        I'm not that technical but I think it is something to do with
        larger bores on the water jacket or simular.
        Helping the water to cool the block more effectively?
        I may be completely wrong that is,it has been known before!
        But it seems once the new type of head is replaced it cures
        the problem?
        I see yours was a 3.0 lt I hope they are now all starting to go
        as well as I was thinking of upgraging
        Hope that is some use
        Cheers Chris
        GOT NO COWBOYS HERE?
        • #19
          Originally posted by lucky
          Richard.
          Correct, no turbo light on the 3.0 even on my runner theres no turbo light, just the engine check light which is red.
          My 4x4
          My choice
          Back off
