I've got a leak from the differential, and Toyota are suggesting £370 plus VAT to fix it, are they having me on?
The pinion oil seal was weeping when I bought the truck (1994 2.4 2WD), and after a quick read of the Haynes joke book it looked pretty easy, so I go tthe oil seal (£10), had the prop shaft and flange off, and tried to fit it. It was a hell of a tight fit and in the end I wedged it in at an angle and couldn't remove it or square it up. Anyway, got another one, tried again, same result after more time, and now it's leaking a lot more than it was. I spoke to the local dealer today and they reckon that cos I've disturbed the pinion nut teh whole diff needs stripping to correct the preload/lash/whatever and something about a collapsible space behind the companion flange.
Frankly I think they're trying to take the pis* or is this really a much bigger deal than whacking in a new seal? The truck drives fine, and is smooth enough up to 80mph so as far as I know the bearings etc are okay. With the companion flange off and nut removed, there is a bit of slop in the pinion, I assumed that was normal when it was just hanging out of the diff.
Help! Cheers guys/guyesses
