Steering Gear Seal
  • Steering Gear Seal
    My steering gear - box has blown a seal where the steering column shaft attaches to the the box. Has anyone got a part no or advice on this problem.
    I've just had a look at the EPC and if the seal is the one around the splined shaft going into the box, then this doesn't seem to be listed seperately - it's all one lump. Your best bet might be to remove the offending item and try a local bearing supplier
    Roger
      ROGER thanks for looking mate, Ive added some Power Steering Additive which swells the seals but im not crossing my fingers with it yet.
        be a bit slippery to keep em crossed
        My 4x4
        My choice
        Back off
          getting a box off HILUX as this is a none serviceable part .
            Could try giving the seal extra fish
            Roger
              I have the exact same problem with mine at the moment. What hilux models do they match Marky?
              Derek :
              1990 Hilux Surf SSR Ltd
                STIMPY30- Darren our northern mechanic chap told me to add some power steering additive which swells worn seals, so far its working as a temp fix.
                  re steering box
                  i have a couple of good secondhand boxes if anyone is intrested
                  07836288198
