electric windows
  • electric windows
    got a big problem !! drivers window is jammed halfway .. will not go up or down nor will anyother windows work !! plus back window doesnt work from inside any ideas where to start ..might be fuse but cant find which one !!need to sort rapid as it is drivin me mad!! any help would be great!!
    tried the window lock switch???
    Tim
      YEP done that ! also tried swappin armrest controls with another moter
        Hi
        2 locations for fuses, 1 box in drivers foot well and another under the bonnet.You say the rear doesn't work from inside does it from the key outside still?
        Steve
        Should have bought a 3ltr
          yeah the back window works with the key , but slowly as if the battery is goin flat!!
