Ok first post time
  i have just got my surf
 a 1991 2.4  Green colour but when i try to open the rear window from the outside nothing happens
 so i can only load stuff from inside the truck
 any suggestions bearing in mind im as a technical minded as a tadpole cheers for help inadvance caaw.
Sorry if this is posted in the wrong section but i was unsure where to stick it
 any suggestions bearing in mind im as a technical minded as a tadpole cheers for help inadvance caaw.Sorry if this is posted in the wrong section but i was unsure where to stick it
