Does anyone have the Wiring Diagram for a 2000 3.4L 4runner?  I need to disable my daytime running lights because of the HID lights I installed.  If someone can post it would be much appreciated.
Disabling Daytime Running Lights - Help -
Hi Rob,
The answers a bit closer to home for you on Yotatech
http://www.yotatech.com/~corey/tech/ducky_drl/ducky.htm
Rich.If life's an uphill struggle then downhill from now on can't be that bad?!
