I've got a 2nd Gen 4Runner and it has a weird problem with the main beam flash.
The headlamps work normally, dipped and main beam. However, when you pull back on the main beam switch, in order to flash, nothing comes on in the headlamps. The full beam light comes on on the dashboard and the headlamp relay under the bonnet activates, but nothing lights up in the headlamps.
Any ideas on what could be wrong?
