Hi all,
I recently acquired a 3.0 2nd gen to join my 2.4 2nd gen. I went to move it tonight and the courtesy lights wouldn't go out, all doors including the tailgate are shut fully. I'm guessing it's a knackered courtesy light switch. However, the little light on the steering column that illuminates the ignition switch won't go out either. As it's late, dark and very wet outdoors, I've just switched the courtesy lights off and removed the bulb from the steering column for now. Any ideas what might be causing it though just in case it's something more serious than a courtesy light switch.
